Can someone tell me what kabel i need to instal on de car lights, so the pioneer wil automatic dim, on a f900bt? Is it the pink one with a label called ILL?
I couldn't find it in the installation manuel.
Thanks i advance.
Thanks i advance.
weird
the pink wire (at least here) is for VSS, there should be a orange/white wire labeled ILL.
hooking up the corect illumnation wire to a wire in the car that shows 12v when the lights are on will make the AVIC dim automaticly.
