Ok, So i got the TA2011 maps and the generic license file form here. Now my system boots up, but never leaves the System Startup message. hereswhat I did
Booted into Testmode
Backed up the License Files, Map, POI, Building, and Speedcam folders to my SD card
Deleted the License Files, Map, POI, Building, and Speedcam folders from Myflashdisk
Copied over the New files from the SD card
Now my system will not leave the System startup message. I can click on audio input even though the message is there and change audio sources, but the maps never come up. If i try to access the maps, the unit will reboot. What did I do wrong here?
Edit: I did rename the map files to match the names of the files that were on the unit prior, truncating them down by removing the tomtom part of the file name.
