This is the complete file format spec, as far as i understood it:
Image File Format
* Position | Field | Size
* 0 | Header Record (F1 only) | 40 bytes
* 0 | Header Record (F2 only) | 48 bytes
* variable | GZH Record (Gzip Header) | 12 bytes
* variable | GZF Record (Gzip File) | variable
* variable | Directory Record | variable
Header Record
* Position | Field | Size | Example Value
* 0 | Magic Bytes (F1 only) | 4 bytes | F1 F1 F1 F1
* 0 | Magic Bytes(F2 only) | 4 bytes | F2 F2 F2 F2
* 4 | Number of files | 4 bytes | 74 0C 00 00
* 8 | Header Size (F1 only) | 4 bytes | 28 00 00 00
* 8 | Header Size (F2 only) | 4 bytes | 30 00 00 00
* 12 | ? Unknown ? | 4 bytes | 00 00 00 00
* 16 | ? Unknown ? (F2 only) | 4 bytes | 30 00 00 00
* 20 | ? Unknown ? (F2 only) | 4 bytes | 00 00 00 00
* var | GZH Block Offset | 4 bytes | 30 00 00 00
* var | GZH Block Size | 4 bytes | 70 95 00 00
* var | GZF Block Offset | 4 bytes | A0 95 00 00
* var | GZF Block Size | 4 bytes | 62 E6 83 00
* var | Directory Block Offset | 4 bytes | 02 C7 84 00
* var | Directory Block Size | 4 bytes | E5 5D 01 00
Gzip Header Record
* 0 | GZF Record Offset | 4 bytes | 80 68 00 00
* 4 | GZip Filesize | 4 bytes | 75 00 00 00
* 8 | Unzipped BMP Filesize | 4 bytes | 84 02 00 00
GZIP File Record
* Position | Field | Size | Value
* 0 | Magic Bytes (gzip) | 3 bytes | 1F 8B 08
* 3 | Rest of gzip data | variable |
Directory Record
* Position | Field | Size | Style | Example Value(s)
* 0 | Type1 | variable | ASCII | "pOver", "vi", ""
* var | Delimiter | 1 byte | HEX | 5C
* var | Type2 | 2 bytes | ASCII | "2M", "32K", "GZ"
* var | Filename | variable | ASCII | "007_2M_OM-151.bmp"
* var | Delimiter | 1 byte | HEX | 00
