Question about speed warning and parking brake mod
By spta97 · Mar 21, 2012in Hacks/Mods💬 7 posts👁️ 1,807 views
Posted Mar 21, 2012 · 21:41 UTC#1
I have a F90BT and have done the software update to allow navigation usage when moving. The steps I followed are:
1) Grounded the parking brake wire
2) Updated the following section of the pioneer.ini file:
[pioneer]
parking_break_speed=16.0
hide_logos=1
As per the instructions, I updated this value to 128.0. The mod works fine, however I get the warning message when I hit approximatly 80 MPH (128 Km/H).
I figured I would just raise the value, however it only seems to work with the value 128.0. I tried 256 and 160, and both values would cause the triangle car icon on the map to take up 1/2 the screen and the warning would come on once I hit about 10 MPH.
Is there a value that I can pic that is over 80 MPH?
Posted Mar 28, 2012 · 04:27 UTC#2
Anyone?
Posted Mar 28, 2012 · 11:36 UTC#3
this is odd. Maybe grab someone elses mod and put it in and see if that makes a difference. You may be doing something funny as you change the text and save that you may not be realizing.
Posted Mar 28, 2012 · 20:33 UTC#4
Thanks - I was editing the file through WinRar and just replacing it. Do you know where I can find another set of files? I have the 3.0 Naviagation update.
Posted Mar 29, 2012 · 00:00 UTC#5
on a windows PC? get 7zip unpack then use windows notepad so you can properly open and save it. or download daftias mod in the complete mods/themes section. This combines numerous mods in it including softmod for ebrake
Posted Mar 30, 2012 · 22:56 UTC#6
Thanks. I will look to see if I can find that. I had to back out all my mods a while ago as they caused nothing but problems. The only mod that I was interested in was the parking brake mod - I used the existing files on the AVIC and just modified that. Will the above mentioned files overwrite the files that are on the AVIC?
Posted Mar 30, 2012 · 23:27 UTC#7
It over writes many but not all. Maybe put your backup on to give you a fresh start then do the mod.
