Just got the new avic x940bt installed! Nice!
By mdman · Mar 24, 2012in General💬 25 posts👁️ 15,288 views
Posted Mar 24, 2012 · 20:04 UTC#1
Hey folks, i just got the new avic x940bt installed in my 2006 gmc yukon, i must say I really like it, coming from the x930bt. OK I have paired my htc vivid (android) to the unit and I can confirm that it works in regard to being able to get Pandora, aha radio (blutooth) , also the power and audio/video harneses seem to be the same the x930bt , as the installer said he did not have to use the harneses that came with the x940bt, my video bypass also still works with the harness from the x930bt on the x940bt. OK navtek maps are fine also, I now see major buildings in downtown areas, there is now a 2d up on the maps now.
Hope this helps some of U folks out in ur buying decision.
Posted Mar 25, 2012 · 01:11 UTC#2
hey i was just wondering what you did to bypass ur x940bt i just went from the x920bt and i tired to same way to bypass but it didn't work for mine. It shows video until i hit about 25mhp then the video shuts off. Any suggestions thanks in-advance for ur help and time.
Posted Mar 25, 2012 · 13:29 UTC#3
Nice!
Can you make software backup from your X940BT?
I would like to take closer look at new USER folder.
Posted Mar 25, 2012 · 13:42 UTC#4
the installer did the bypass, so I'm not sure how it was done.
Posted Mar 25, 2012 · 13:46 UTC#5
Nice!
I'm not sure at this time.
Posted Mar 25, 2012 · 18:38 UTC#6
Nice!
Some of these 940/140 guys may be new to this series of units so you might want to point them to a thread or explain to them how to do this. BTW, did you guys ever get anywhere with the 120/130 hack effort?
Posted Mar 25, 2012 · 23:51 UTC#7
HowTo backup Pioneer UI - youtube
! at this video Jason uses testmode.key file, but it is not nessasary.
  1. push and hold HOME button, turn on ignition, keep home button pressed and press previous button, next button, previous, next and so on while keeping home button pressed until the unit restarts, it should enter testmode.
  2. move down and enter FILE MAINTENANCE,
  3. go to USER, select COPY on the menu,
  4. move up, and go to SD,
  5. select PASTE on the menu,
  6. once it finish - BACKUP IS DONE. It may take up to 15 minutes to finish.
  7. now hold EJECT button for 5s to get to sd card, take it and connect to pc,
  8. copy USER directory somewhere safe on your computer.
If you have problem or just would like to know more- you are welcome here.
Posted Mar 26, 2012 · 08:45 UTC#8
Just installed my avic-x940bt yesterday not sure how i feel about it yet. I had a Kenwood DNX-6960 installed in my truck before the avic-x940bt.
There is a couple of things that bug me about the avic-x940bt
First one is when the deck first powers on and i hit the home button it then go's to a warning screen that i have to hit OK then it will go to the screen with the map (I can change it to the eco screen or reverse camera instead of the map screen.) but can not get it to go straight to iPod screen or home screen does your do the same thing.
Second thing is where is the Advanced Sound Retriever i can't find it anywhere i was really looking forward to this feature as i had it in another pioneer deck and it works works great when using iPods.
I am thinking of taking it back and swapping it for a AVH-P8400BH.
Badboy
Posted Mar 26, 2012 · 14:20 UTC#9
Dont hit the HOME button. Just leave off on the iPod source and it will reboot to that screen the next time. That OK screen is always going to appear however when you access any screen that deals with the map. Its by design and you cant change it. Its the same way with the Kenwood you had.
Not listed in the specs anywhere for this unit or any of the navi units. Its is included with the AVH units however so the 8400 might be the unit for you. Do your homework though. There are other features the navi units have that the AVH units dont.
Posted Mar 26, 2012 · 19:20 UTC#10
Thanks It is a nice deck better then the kenwood I had the sound is way better bass hits better and highs are more bright.
I really like the volume knob on the x940bt and like the top load cd slot so I am still deciding if the pros out way the cons
Do you what are some of the features that the x940bt has over the p8400bh besides navigation.
Badboy
Posted Mar 27, 2012 · 02:55 UTC#11
the shop that installed it did the bypass, so i do not know what they did.
Posted Mar 27, 2012 · 03:17 UTC#12
Recheck your connections for the bypass. The bypass proceeder is likely the same as the previous units and usually doesn't change between units in the same series.
Posted Mar 27, 2012 · 09:36 UTC#13
I can confirm the bypass for the avic-x940bt is the same as the avic-x930bt just move the mute wire up one pin and ground it.
Posted Mar 27, 2012 · 15:52 UTC#14
Along with the P brake wire.
Posted Mar 30, 2012 · 14:39 UTC#15
since your AVIC bypass works when moving slow, your parking brake wire IS grounded.
however since it stops working when you go over the certain speed it stops working means that your problem is with the mute wire, it is either in the wrong pin or or not in all the way, or not grounded.
Posted Apr 19, 2012 · 01:27 UTC#16
I just got my x940bt installed but I haven't bypassed it yet. I had it done at Best Buy. I know not the best place to have it done, but they did alright. I like it so far. One complaint I have is that there are some snaps and crackles when listening to FM (but not CD or AM. I haven't tried other sources yet). Best Buy replaced the antenna adapter but that didn't cure it. Another complaint is that the turn by turn directions do not mention the street names (usually - it seems to speak highway names). The street to turn on is on the screen only. Otherwise, I'm very happy with it. It's also cheaper than the x930bt on Amazon - another plus! :mrgreen:
Posted Apr 19, 2012 · 17:53 UTC#17
The turn by turn not having text to speech is really bothering me. My cheapo valor 868 HU even has it.
Posted Apr 19, 2012 · 20:38 UTC#18
what kind of car is this in? and what kind of antenna does it have (shorty, shark fin, in glass)? they might have used the wrong antenna adapter (like they might have needed to use one with a built in signal amp)or there might be a signal amp in the car that is not getting powered up.
i have also been noticing a lot of newer cars with either shorty antennas or in glass antennas that never perform as good as the original radio as far as reception no matter what brand we swap it out for. i think it has to do with the OEM radio being specifically being tuned of the odd or unusual type of antenna, and pioneer (and everybody else) is still expecting cars to have old school stalk antennas.
Posted Apr 20, 2012 · 02:32 UTC#19
I have a Mercedes C230. It has a short little antenna on the roof above the rear window - I think it's an amplified antenna. The adapter they installed looks like the Metra 40-EU10 (Amazon says it's for my car but Best Buy doesn't list my bar as application!).
Are there any better options?
Posted Apr 20, 2012 · 18:07 UTC#20
i would check to make sure that the antenna amp is getting powered up then,
there is also the metra 40-eu55 which does have the same plugs but has its own signal amp, also make sur ethat your car does not have dual antennas like a lot of new German cars do in which case the 40 eu56 might work better.
Posted Apr 22, 2012 · 14:01 UTC#21
there is text to speech, you just have to enable it through settings
Posted Sep 16, 2012 · 20:17 UTC#22
I just had the avic-x940bt installed, they were able to use some parts from the prior unit that I had. all works well execpt for the back up camera. the image is reversed and there is no optin to change it, all i can find is to turn it on/off and change from positive to negative. this is the camera from prior unit not a new camera. any help would be great.
Posted Sep 21, 2012 · 23:41 UTC#23
it is going to depend on you camera, some cameras have a switch or wire that needs to be cut for image mirroring, either you camera needs to have this changed, or your camera was not trully designed for being a reverse camera. some radios do have a setting to mirror the image but most do not. i would investigate the manual for your camera.
Posted Sep 22, 2012 · 00:58 UTC#24
Anyone have the manual posted somewhere for the 940? I updated my 930 and would like to see if it HS some of the features in the new radio
