Few nav. related D1 questions
By illzguju · Jan 28, 2007in Problems/Troubleshooting💬 13 posts👁️ 1,684 views
Posted Jan 28, 2007 · 06:00 UTC#1
Hey all, a bit new here so bear with me! I have enjoyed going through these forums thus far and they have helped me a LOT. Here's the scenario, I have a used AVIC-D1 installed on an 05 Saab 9-2x. The installation was done by myself at home. VSS and reverse wire connections are NOT made (I got lazy :( ) The parking brake mod is done and works fine. The antenna did not come with the part to actually attach it, so it's kinda dangling at the moment. My question is 1) Can I get a replacement antenna booster (?) from somewhere to actually mount the antenna on my windshield? and 2) My nav is a bit flakey at the moment (I reset the system after installation and all that) Sometimes it works great, sometimes it has my car going all over the place and nowhere near where it really is. I know this is partly to blame for not connecting the VSS. Would mounting the antenna properly help this significantly, or do I HAVE to connect the VSS?
Thank you all in advance for any help you can provide. Cheers!
Posted Jan 28, 2007 · 06:18 UTC#2
the vss is only going to cause about 3 feet variance on the map. placing the ant? I am guessing your talking about the gps ant.? if so, you want to make sure that it has a nice line of sight of the sky, not hitting say a metal panel on its way.
Posted Jan 28, 2007 · 06:20 UTC#3
Considering we have basically the same car (per your sig at least), where did you mount your antenna? What does this extra piece of mounting equipment (which I do not have) do? Is it a signal booster, or only something adhesive to mount the antenna? Thanks again!
Posted Jan 28, 2007 · 06:34 UTC#4
I placed the ant.'s under the center of the dash, where the square panel can be removed, its plastic. For optimal signal though you would want to go outside or on top of the dash, but again I went under the plastic panel and I have no problems. I dont know what extra piece your talking about.
Posted Jan 28, 2007 · 11:20 UTC#5
What do you mean the antenna didn't come with the part to attach it? Do you mean the square magentic pad? Having the antenna touching metal/square pad will definitely effect navigation accuracy
Posted Jan 28, 2007 · 19:38 UTC#6
yup, that's exactly the part i mean. since i bought it used, it didn't come provided. Can I purchase that somewhere else?
Posted Jan 28, 2007 · 22:43 UTC#7
you can mount it to metal also that will help. the metal helps reflect the gps signal. If you mount the gps ant. where I did, you will need to get the metal square.
Posted Jan 28, 2007 · 22:49 UTC#8
tillithz don't you mean he won't need the metal square?
Posted Jan 28, 2007 · 22:52 UTC#9
no he will need it cuz its the plastic air ducts that dont have any metal around them and where you would stick the gps ant.
Posted Jan 28, 2007 · 22:53 UTC#10
Sorry I misread your post. It sounded like you put it on metal.
Posted Jan 28, 2007 · 22:54 UTC#11
probably sounded that way, I am not great with wodrs hehe
Posted Jan 29, 2007 · 04:38 UTC#12
any idea where I can obtain a replacement metal square?
Posted Jan 29, 2007 · 15:43 UTC#13
pioneer? sorry I cant think of anyone else.
