I installed a Boyo VTL110 license plate camera. When my car (BMW X5) is not running the picture looks fine (reverse and split view works). When the car is running the picture has horizontal interference. I can still see the picture okay but the whole screen is covered with lines. At first I thought I had bad connections as I am using the same hot and ground wires for the radio. I tried grounding directly to the car's body and pulled hot from an unused connector in the fuse box. Now the static is worst than it was before!
Other video works fine. I played a DVD and it looked fine with car running or not. I also tried connecting a video camera to the reverse input and the image looks fine. So it appears that the problem is the wiring. Can a noise filter help me?
I have searched this forum and the web and I can't find anyone with a similar problem. I really don't understand why this is happening; hopefully someone here has some insight.
