New APP CarMediaPlayer
By worm · Mar 26, 2012in AppRadio, AppRadio 2, AppRadio 3💬 14 posts👁️ 3,357 views
Posted Mar 26, 2012 · 22:54 UTC#1
Free Download from the APP store,Iphone type interface
Posted Mar 27, 2012 · 15:32 UTC#2
The new interface is good but it doesn't let you see podcasts in your music library. You can manually play them by going through the iPod app on the phone but it doesn't show the track info of the podcast when you click the artwork on the AppRadio. Its a good start though and I hope that Pioneer will replace the crapy music app on the unit with one like this.
Posted Mar 29, 2012 · 18:39 UTC#3
This is a great start. This needs to replace the existing interface.
Personally I feel like they should only include the Radio and Bluetooth by default, everything else should be an app and further more make it so we can put these apps on our home screen and not behind a menu. From there have it launch the appropriate app for what you are doing.
Edited Mar 29, 2012 by bit_bucket
Posted Apr 03, 2012 · 19:06 UTC#4
Just like other newly released app's, this one showed up in the App Radio app after it was released into the store. Makes me think that this is all just XML based list of apps that Pioneer modifies adhoc.
Posted Apr 03, 2012 · 20:05 UTC#5
It is :wink:
Posted Apr 03, 2012 · 20:32 UTC#6
Well this is the way they should all work. I've been using it the last couple of days, it's smooth, intuitive, quick and I can easily navigate for the song, artist or playlist. I sent Pioneer an email and said this is how their whole platform should work.
Posted Apr 03, 2012 · 21:08 UTC#7
it doesnt list my playlist in the correct order, i havent really played around with it just used it on the way to work this morning but my songs in my playlists were alphabetical
Posted Apr 03, 2012 · 22:16 UTC#8
I'll check on the way home, but that didn't seem to bother me. I could use my finger to move everything around as I would on my iPhone. It's much improved compared to their iPod interface.
Posted Apr 04, 2012 · 13:32 UTC#9
Much agreed. I left a review on the App Store that stated they should make the App Radio work this way. I have a feeling that their iPod interface basically using the iPhone's own video-out mode, with buttons sandwiched around the sides. I don't have a video-out cable for my iPhone but I imagine that if I did, it would display exactly what appears in the AppRadio's "iPod" interface, only without the arrow buttons around the sides.
I would say that this is a backwards-compatibility issue, that they couldn't write a touch-enabled app that would run on an iPod classic, but iPod classic isn't supported with the AppRadio.
Maybe the guys who do AppRadio Jailbreak can chime in on how it works, but to me it seems that the CarMediaPlayer's touch interface is running on the iPhone, only using the AppRadio as a display and controller. Just based on how long it takes the App Radio to switch modes and update the display, I don't think the head unit has the processing power to run a smooth, swiping, finger friendly app like that.
So unfortunately I don't think we'll ever see the CarMediaPlayer app replace the stock iPod functionality.
Posted Apr 04, 2012 · 15:36 UTC#10
I've found evidence in the operating system that supports this claim. The iPhone provides a "video" stream that is displayed in the center of the screen and it accepts events for each of the buttons on the left and right.
Posted Apr 09, 2012 · 18:17 UTC#11
I left the review on the appstore telling that iPod Out interface is generated by iPhone itself. If you use a display out cable from the iPhone you don't get that interface. It's activated by a special command, or resistance in the cable. I don't know. The problem with CarMediaPlayer App is that isn't embedded in the iOS. iPod out can be always displayed. It doesn't matter what app you're running in the iPhone. While CarMediaPlayer needs to be running to send out video signal.
We need Apple to redesign the iPod Out interface, or Pioneer to add CarMediaPlayer App to the AppRadio firmware.
Edited Apr 09, 2012 by Xradeon
Posted Apr 09, 2012 · 20:59 UTC#12
The radio tells the iPhone to launch an app called "iPodOut.app" located in /Applications on the device. It continuously runs in the background while the phone is plugged in. If you run it manually with a display out cable plugged in, you will see it on your TV.
They did this for the AppRadio 2. Hopefully we can hack the new firmware onto the older unit.
Posted Apr 10, 2012 · 07:16 UTC#13
When will we know if this can be done?
Posted Apr 10, 2012 · 11:03 UTC#14
When and if it gets done.
