Broken SD slot
By speedmatt · Mar 27, 2012in Problems/Troubleshooting💬 3 posts👁️ 1,890 views
Posted Mar 27, 2012 · 02:42 UTC#1
Hi, i have had an 7010 for a few years now and this forum has been quite helpful over the years, however i cant find a solution to my problem. My screen hasn't been doing much recently, just black. so i looked up possible issues... what i found was that a reinstall or update to the system could correct this. well, it looks like the only way to install this update is via SD slot. My slot does not seem to want to hold cards anymore, has anyone experienced this before?
help is much appreciated. thanks
Posted Mar 30, 2012 · 17:51 UTC#2
like your SD slot wont keep a card inside or it wont read the card anymore?
if it just wont stay locked in, will it work if you just held the card into the slot while the update was running (WARNING, if this does work, you will need to make sure that you are holding the card all the way in for the entire time, if it slips out, this could really mess up your AVIC)
Posted Apr 02, 2012 · 00:38 UTC#3
it will not keep the card inside, and if i do try holding it in by hand. It will not recognize it. the unit is pretty useless as it is right now, all i get is radio.
