What is the best way to bypass the parking brake on the X940BT?
By micnet · Mar 28, 2012in Hacks/Mods💬 8 posts👁️ 13,156 views
Posted Mar 28, 2012 · 15:52 UTC#1
What is the best way to bypass the parking brake other than connecting the green wire to an on/off switch?
Posted Mar 28, 2012 · 17:41 UTC#2
Look up the AVIC-X930BT video bypass procedure, its the same :)
Way Better than the on/off switch, which won't work anyways once you start moving :P
Posted Apr 02, 2012 · 01:47 UTC#3
What he said!!! :eek:
Posted Jul 09, 2012 · 02:38 UTC#4
1. On the RCA connector, move the yellow/black stripe wire (mute wire) up 1 position, so that it is sitting next to the red wire after the move
2. Connect the mute wire (from RCA connector), the light-green parking brake wire (from radio power cord) and the black ground wire (from radio power cord) together
3. Either 1 of the above 3 wires can be tapped to connect to the ground wire of the wiring harness for your car.
This link pretty much tells you how to do it.
Posted Aug 10, 2012 · 02:01 UTC#5
what do you do if the person who installed your radio didnt even use that white harness. they only used the black one. please someone help me figure this out.
Posted Aug 11, 2012 · 15:51 UTC#6
Take it back and make them do the install as it should have been done when you paid them to do it right the first time.
Posted Aug 13, 2012 · 23:28 UTC#7
What exactly does the bypass, bypass? I understand it allows for the use of some maping functions while driving, but does it bypass any of the startup screens?
Posted Aug 22, 2012 · 20:04 UTC#8
If you dont have that harness, you can connect a very small connector to the corresponding pin on that plug on the back of the radio, and connect it with a short wire to the phillips screw right above the plug.
