AVIC Z140BH with GMOS-100 questions
By rzuffi · Mar 31, 2012in General💬 14 posts👁️ 4,832 views
Posted Mar 31, 2012 · 21:23 UTC#1
Ordered a new AVIC Z140BH the other day and I should receive it this week.
I own a 2012 GMC Acadia and Crutchfield noted I needed the GMOS-100 adapter to maintain onstar, steering wheel controls, bluetooth, back-up camera, etc.
My question is: Will this GMOS-100 adapter allow the steering wheel controls to control the Z140BH? Or do I have to purchase one the the Pioneer steering wheel controllers and somehow wire it to the GMOS-100?
Also, will this GMOS-100 adapter allow the Z140BH to use the car's mic? I really would rather use the mic that comes with the car's bluetooth system.
Posted Apr 02, 2012 · 14:45 UTC#2
bump
Posted Apr 05, 2012 · 02:53 UTC#5
ok, so I had a sound store install everything today. They had major issues making everything work. They finally got it to work, then I took it home. I went back out a half hour later and nothing worked. No Z140bh, no onstar, no bluetooth, no chimes...
Taking it back to them tomorrow to give it one last shot...
Are there any know issues with Pioneer units and the GMOS-100?
Posted Apr 08, 2012 · 21:28 UTC#6
help. anyone else having issues with gmos-100?
Posted Apr 09, 2012 · 12:56 UTC#7
Any updates on what caused the problem? Is it working now?
Posted Apr 10, 2012 · 01:22 UTC#8
I'm interested as well. People either have nothing but issues or the install works fine so I'm a bit worried about my upcoming install.
Posted Apr 17, 2012 · 09:16 UTC#9
Same setup here in 09 Silverado, everything works fine.
Posted Apr 17, 2012 · 15:01 UTC#10
Cool, thanks. I think you need to follow the instructions regarding the programing. If not the system won't work right. But that is just what i think.
Posted Apr 22, 2012 · 14:30 UTC#11
An update to the GMOS-100. Everything worked as stated. But I did not like the way it interacted with my truck. The following interactions did not work good in my opinion. Bluetooth, backup sensor chimes, door chimes, and the turn signal was horrible. PAC IS MUCH BETTER. Just my opinion
(null)
Posted Apr 23, 2012 · 03:25 UTC#12
I agree on it now working the way you want. I am doing my install currently and I have decided to return the GMOS-100 and go with the PAC. Now I have to run reverse and park brake wires I think...
Posted Apr 23, 2012 · 13:53 UTC#13
The PAC supplies the reverse, VSS and the park brake wire. You might want to check out the bypass for the unit, it is worth it especially if you have kids (even if yo don't). Good luck with the install.
Few other things i didn't not like about the GMOS-100:
XM preview message on my DIC
VSS showed my truck to be 200 feet ahead of my truck
the chimes do not sound crisp
This is just some more information for others trying to find information on the GMOS-100. I could not find much when i was doing research. I have an '09 GMC Sierra, therefore if you have an older model it migh work different for you truck/car.
Edited Apr 23, 2012 by alejalva
Posted Apr 23, 2012 · 17:53 UTC#14
For the newer GMLAN cars PAC supplies those signals. Older Class 2 cars like the Corvette have to find VSS, Reverse, Park Brake, and even Ignition (unless you want to rely on the PAC generated Ignition signal which I do not) themselves.
I would have expected the GMOS to work better on the newer cars. The '09 Sierra is a GMLAN 29-bit (the newest type of GMLAN) and therefore the easiest to work with.
