Hey, I'm just wondering if this is a broken unit, or if this is what I should expect from an AppRadio . . .
I bought 2 new AppRadio's at Best Buy last week when they were having the $199 sale. I was going to buy one for my wife for our anniversary, but they were so cheap, I decided to upgrade my U310BT while I was at it. Since my car has an aftermarket wiring harness in it already, I hooked mine up first. This is far from my first radio install and everything is hooked up correctly. I hooked up the parking brake wire to a SPST switch to ground, ASWC for steering wheel controls. Other than that it's not a complicated install. No external amps, no backup camera, etc.
From day 1 it has been a hassle. It has needed to be reset just about daily. It seems like every time it has been off for a while and goes through the "Pioneer' splash screen bootup process, you have about a 50/50 chance of it working. Sometimes, the touch screen will freeze, not letting you press that initial "OK" to start the radio. Sometimes, it will boot up but not sense the phone is plugged in. This morning, I had it boot up, no iPhone plugged in, turned on the radio, and had the whole thing freeze with the volume adjustment on the screen. The volume buttons still worked but the touchscreen was frozen and the home button didn't work. Plugging in a phone didn't help.
The most frustrating thing about this is that every time something boneheaded like this happens, I have to hard-reset the friggin thing, losing the clock (which, come on, it can't auto-set the clock? My crappy U310BT could at least do that!), radio presets, screen settings, etc.
I have had to reset the thing every single day I've owned it.
This is happening on OS 2.22 and 2.45.
At this point I'm not sure if it's worth the hassle to even unpack and install the second one, or if I should just return both of them and hunt for something else.
Is this normal? How often do you guys hard-reset your units?
