F900BT Frozen
By firedragon · Apr 04, 2012in Problems/Troubleshooting💬 13 posts👁️ 1,761 views
Posted Apr 04, 2012 · 14:18 UTC#1
hi there i got f900bt with version 4.1 update this morrning my unit was working fine after i went to top up the petrol and the unit just froze it keep on loading up to the navgate screen and then its froze i have try to use the reset button but still its won't has anyone had this problem before if so can someone help me me pleaese thanks
Posted Apr 05, 2012 · 11:31 UTC#2
sounds like you made an error or your system is having a bad time with the files. Re downlaod and re install to make sure nothing is currupt. make sure you have freshly formatted SD card before you put it on.
Posted Apr 05, 2012 · 15:14 UTC#3
so i should try re download version 4.1 again and try to load it up ? i try this yesterday but it would not resinstall just stay on the same screen could be because i haven't reformat the sd card yet
Posted Apr 05, 2012 · 21:21 UTC#4
did you install maps with it? are the in the correct place? yes i would completely re do it following directions perfectly
Posted Apr 06, 2012 · 07:57 UTC#5
nope i got CMD200 sd for map its just the frimware that i intsall still trying but no luck keep staying on the pioneer logo
Posted Apr 06, 2012 · 12:25 UTC#6
so very even gets to please wait startup in process? is this a us or eu model?
id grab the maps out of my backup place them in correcrt files on computer within the 4.001 then format SD card and place all files on card. try it that way
Posted Apr 06, 2012 · 13:05 UTC#7
its the eu model mate
Posted Apr 06, 2012 · 13:08 UTC#8
how can i get the map out of the backup places
Posted Apr 06, 2012 · 18:38 UTC#9
i just put version 2.9 on the sd card this afternoon i it did the upgrade which didn't wen i put version 4.9 on it the screen still stop at the pioneer navgate loading screen but this time its ask me if i wanted to remove all poi and setting in which i did yes the unit reset but still won't load into the main screen am i still doing something wrong ? :x
Posted Apr 07, 2012 · 07:23 UTC#10
i manage to get it into the main screen now but it will not let me use the av soruce or nav when i check on the system info its version 2.9 no map date
Posted Apr 08, 2012 · 14:00 UTC#11
did you make a backup before you started playing around? if so find your backup files on your comp you need to go to apl2/igo/content and copy maps pio and place them into the same locations on the hybrid update. where did you get your update sfware?
Posted Apr 08, 2012 · 17:33 UTC#12
i got the software from pioneer site mate
Posted Apr 09, 2012 · 12:01 UTC#13
then you need to call them that shouldnt happen!
