Looking for some insight
I have read on this site that the vss wire is located drive side connector pin 6 yellow wire..
I found the connector and connected the pin 6 wire ... however when connected the wire does not register when monitoring the AVIC at speed...
I am assuming that the connector that I should be using is the OBD-II connecter pin 6 yellow wire...
any help would be very much appreciated....
