Is there anyway to connect an android powered phone to an avh-p1400? I've tried debugging mode etc.
Sent from my HTC Thunderbolt
Other then BT likely not.
It isn't equipped with blue tooth:-/ any chance a hack could "unlock" that feature? Kind of like a Rom for a rooted phone?
No.
should have gotten the 2400 with BT
I bought the 2400 on a Friday and Friday night I did some research.. on Sat morning I went back and ended up buying the 8400, I think it's worth the expense if possible. Bluetooth works great with an HTC evo 3d, both streaming music and phone.
As for the hack, I am sure it is possible as there would be a bluetooth radio on both models but enabled in the software in the BT series. You would be the man if you were to figure that one out. I have thought about the overall OS and I would bet it is Linux based and uses a standard file system, processor and memory. It basically handles all these file types exactly as your PC would
