I can't seem to find any info on this anywhere online. I hooked a brand new ND-BC5 rearview camera to the appradio and every time I click the camera "on" by manually pressing the button, it won't go off. Not after the car is shut off, even if for more than a day, and is restarted, it always comes back on to the camera mode. Makes the radio and everything else useless and I have to do a hard restart, resetting all my stuff. Pioneer claims they have never heard of such a problem. Said it wasn't cutting off because I hadn't hooked up the pink reverse line. I told them I didn't care about it coming on when I went in reverse, I just wanted to be able to turn it on and off as I please, which is how it is advertised. I don't even know what wire I would tie into? I've done all the work and I'm not going to pay $80 for Best Buy to hook up 1 wire that shouldn't have anything to do with the other part working. Has anyone heard of this problem? BTW I'm running version 2.22 if that has any bearing on things.
Rearview Camera won't shut off
I think I know what your problem is. If you go to your settings and change your rear view camera options to ON. It may be set to (ON with ground) and that is why it's not shutting off. Try that and let me know.
I also have this problem, since i mistakenly chose the 'Normal (gnd)' option. Only thing is, even resetting the unit does not allow me to access the settings to change it back, each time i reset, it goes through the boot up, asks me to confirm my language, then goes straight onto the rear view screen - no amount of button pushing makes any difference.
Anyone got any ideas?
i have this same problem! someone please help!!!
i have pulled the battery, ive pressed reset on front of appradio, nothing works. it always goes back to recerse camera screen.
it sounds like its hooked up wrong
This worked for me. I had set my camera wrong also ,if I put the car in reverse it would turn the camera off long enough to change the settings. Be careful so you dont back over anything ![]()
SOLUTION:
I finally found out how to remedy this....
On Appradio 1 (SPH-DA01), take the pink (reverse) wire behind your radio, and touch it to a 12 volt source (cigarette lighter/accessory), it will take you back to the main screen on your appradio. Then, just go in settings, and change the normal (grnd) to Normal. Wah Lah! Crisis averted. Hope this helps.
