Appradio1 - Missing original Backgrounds
By pistillo99 · Apr 23, 2012in AppRadio, AppRadio 2, AppRadio 3💬 4 posts👁️ 1,156 views
Posted Apr 23, 2012 · 20:58 UTC#1
Hi guys,
after updating the firmware of my appradio, the background has become black. When I select the option "backgrounds" the appradio makes a beep but does not change the background image. Do you know how I can recover the original wallpaper?
I also tried to restore the firmware 2.45 but is no possible to overwrite the same version.
TKS
Posted Apr 24, 2012 · 09:41 UTC#3
did you try this ?
http://www.appradioworld.com/2012/02/how-to-add-custom-background-to.html
and if you unzip original firmware update from pioneer ( v2.45 ) in folder CE66/ you have wallpaper with the two native backgrounds
maybe import it in itunes, and try the upper link.
hope it help
Tks for reply but my questions is about the main wallpapers.... The backgrounds of the clock screen for example
Posted Apr 24, 2012 · 12:15 UTC#4
Hi Pistillo,
I had the same problem with the switch backgrounds as you have.
I just restored the 2.45 firmware as you suggested using this thread: http://avic411.com/index.php?/topic/33495-downgrade-firmware/
You have edit the mpu.bin with a texteditor like notepad and set the version from 2.45 to 2.46 e.g.
Good luck!
