Avic F930BT
By S4 IRL · Apr 24, 2012in General💬 5 posts👁️ 1,686 views
Posted Apr 24, 2012 · 13:04 UTC#1
Hello all, After having a avic F900BT for a year and being fairly happy with the unit I decided to upgrade to the AVIC F930BT. Only having installed it, first impressions are good. The clarity and power of the sound are a major improvement over the F900 unit. Couple of questions though,
.Is it possible to display current speed on map screen as the F900 had this feature i can not find it on the 930
. I could also view altitude levels and other info on the F900 i can not find it on the 930
. And lastly, what is the difference between the F930BT and the X930BT or are they the same just branded different for other markets?
Posted Apr 24, 2012 · 14:05 UTC#2
The answer is no for your first two questions and it was no for the F900 as well with stock firmware. The only difference between current F and X series units is region of the world.
Posted Apr 24, 2012 · 20:26 UTC#3
VBLUE42, Thanks for your reply. Question is can speed and altitude be had on screen with different firmware ?
Posted Apr 25, 2012 · 02:25 UTC#4
No.
Edited Apr 25, 2012 by VBLUE42
Posted May 15, 2012 · 16:11 UTC#5
I'm sure that it is much safer to look over and down at the radio to see how fast you are going instead of looking at the cluster.
