Using GPS while in a tunnel
By jluna1 · Apr 27, 2012in General💬 5 posts👁️ 853 views
Posted Apr 27, 2012 · 01:32 UTC#1
I live in Boston and when leaving the city most of the time it requires to go into tunnels. I recently installed a z130bt in my 03 Maxima. My question is is there a way to get the route guidance to continue while in the tunnel? In some tunnel the guidance doesn't stop but in others it gets stuck on the last turn before entering the tunnel.
Posted Apr 27, 2012 · 03:26 UTC#2
Connect the VSS wire.
Posted Apr 28, 2012 · 00:00 UTC#3
Is that the pink wire? I had it professionally installed. That won't effect the bypass?
Posted Apr 28, 2012 · 01:30 UTC#4
Yes.
No.
Posted Apr 28, 2012 · 01:35 UTC#5
Your correct the VSS is the pink wire. Connecting it has no impact on the bypass
To verify if it's connected
select - Settings
select - Navi Settings
select - Connection Status
You'll get a screen that looks like this
Drive and you should see the speed signal vary and as well when you select reverse the backup signal should change from low to high.
If that doesn't happen the VSS and backup wires are not connected properly.
Edited Apr 28, 2012 by zx6rrdan
