Clock
By TPA · May 01, 2012in AppRadio, AppRadio 2, AppRadio 3💬 12 posts👁️ 2,759 views
Posted May 01, 2012 · 08:14 UTC#1
I have an Appradio 1, purchased in the US but being used in Europe. Firmware 2.5 US version.
Clock keeps resetting to 12:00 am - saturday.
Must be a setting issue. ?
Posted May 01, 2012 · 09:45 UTC#2
wouldn't it be the permanent + and the acc + inverted only ?
Posted May 01, 2012 · 14:57 UTC#3
Hi Yonel - sorry I don't understand your post?
Posted May 01, 2012 · 18:14 UTC#4
i think what he was trying to say was the constant 12v + is switched with the accessory 12v +
This should solve the problem
Posted May 02, 2012 · 03:46 UTC#5
I'll have it checked out by the installer.
Does that have any negative affects on battery drain?
Posted May 03, 2012 · 20:04 UTC#6
I went back to the installer and the CHANGED the batterey / power from accessori to constant . Here is the result:
_Restarting the car (and appradio) the language selezione IS reset ... Pre-selection of language is NOT memorized.
_Clock setting is NOT memorized
_Radio Station settings ARE memorized.
Any idea why?
Posted May 03, 2012 · 23:14 UTC#7
so it was better before going to the installer...? ( so connection was ok....)
when you select the area zone , must be in "other" and not "usa"...can you try this ?
if not, maybe there 's something from firmware ? did you try european firmware ( don't know if it works but...)
Posted May 03, 2012 · 23:26 UTC#8
I've never cracked one of these open but is there a battery that will keep the memory settings similar to a CMOS battery on a motherboard?
Posted May 04, 2012 · 16:27 UTC#9
I did a system reset of the software, reset and saved all time settings and for now, the clock is holding it's time memory
_Clock setting is ARE memorized
Posted May 04, 2012 · 17:20 UTC#10
spoke to soon - after a 3 hour pause, no radio settings or time settings are saved, and the radio keeps switching automatically to 'north america',even when the car is running, which is not where I am located.
and no video viewing is possible, nor any apps in the iPhone (other than phone, radio and iPod but on a blank screen)
back to square one.
Edited May 04, 2012 by TPA
Posted May 08, 2012 · 16:11 UTC#11
How would i open the unit to check for a battery, where would the battery be?- I've had the installers reset all connections, and everything is working again except memory of time, radio stations, country settings etc....basically no memory at all.
Posted May 08, 2012 · 18:20 UTC#12
You would have to open the case and check out the main board. I wouldn't be surprised if the battery isn't replaceable since this is a relatively cheap piece of electronics and designed to never be used again if it fails. You can also check the constant 12V from the battery to see if that's providing enough power.
