Appradio 2 bypass help
By Terlecki ยท May 01, 2012in AppRadio, AppRadio 2, AppRadio 3๐Ÿ’ฌ 2 posts๐Ÿ‘๏ธ 2,537 views
Posted May 01, 2012 ยท 16:44 UTC#1
So I installed the appradio two and so far works great just a couple bug but i cant get my apps to run because i dont have the parking break wire in but problem is i tried soundman bypass with the relay and it wont work because it ask me to hit ok and it wont let me. I tried the swith and i hit the ok button and then it shows me a black blank screen. Has someone else had this problem and how did you fix it??
Posted May 02, 2012 ยท 19:20 UTC#2
Try to disconnect your iPhone/iPod Touch then close all the apps and restart your Apple device. You can also try disconnecting the car's battery for 60sec to reset the radio for sure. I would also stick to using the switch as the relay can be eliminated by firmware updates.
