Good day to all! I'm from Russia, and I also have a problem with avic f-320bt blue screen with winceimg.bin missing. The pioneer service in my country could'n help me to restore it. But they gave me the firmware files from pioneer service site. Here it is (http://www.filedropper.com/qi037avicf320bt) . I try to restore my avic, but fail. I copy winceimg.bin, winceimg.cks in the root of my sd card (4 gb), restart avic, screen with 'Updating image..' appeared, but that's all. It shows me it for 1 hour so my patience run out. Сan anyone has ideas?
Avic f-320bt winceimg recovery files. May be can be usefull.
I did not notice constant with the same response. I have another idea
TECHNICAL BULLETIN
Date: 25/11/2010 No.: 461
MODEL No.
AVIC-F320BT
AVIC-F3210BT
SUBJECT:
Firmware Rewrite Procedure
DETAILS:
- The Firmware package is available as service part disk PEE1045.
- It is not available as download because its size is >2GB.
- The FW contains:
- Platform Version 1.010
- Application Version 1.010
PROCEDURE:
STEP 1 – Deleting the original FW via SD1
- Insert PEE1045 into your PC and open the folder “SD1â€
- Power on the AVIC-F32(1)0BT
- Insert the SD card into the SD slot of the AVIC-F32(1)0BT
- Press the reset button
- Push the “Explorer†softkey (bottom mid)
- Double-click on “MyFlashDiscâ€, select all files and folders
- Double-click on “MyFlashDisc2â€, select all files and folders
STEP 2 – Uploading the FW via SD2
Here is the link to the SD2 files (http://www.filedropper.com/sd2)
you can put the file on another file hosting like mediafire? thanks.
aceeasi problema cu ecran albastru,nu am discul original , cred ca nu am ce m-ai face cu aparatul puteti pune fisierele sd1,sd2 la upload pe filelist sau mediafire ,,va rog
Good day to all! I'm from Russia, and I also have a problem with avic f-320bt blue screen with winceimg.bin missing. The pioneer service in my country could'n help me to restore it. But they gave me the firmware files from pioneer service site. Here it is (http://www.filedropp...qi037avicf320bt) . I try to restore my avic, but fail. I copy winceimg.bin, winceimg.cks in the root of my sd card (4 gb), restart avic, screen with 'Updating image..' appeared, but that's all. It shows me it for 1 hour so my patience run out. Сan anyone has ideas?
daca ai fisierul QI_037_AVIC_F320BT il vreau si eu, sunt pe punctul de a rezolva problema...poate ne ajutam reciproc...
A reusit careva sa il faca ?am dat si eu de problema asta!!
