Z140 SD Card Video Specs
By Workmuch · May 04, 2012in Problems/Troubleshooting💬 5 posts👁️ 3,239 views
Posted May 04, 2012 · 15:47 UTC#1
Hey guys, new member 1st post and awesome forum. Thanks, ton of great info.
Got a new 140bt and I'm trying to figure out the best video format & specs for the SD card videos. (and USB HD videos)
I have tried h264 mp4, 800x450 (same scaled ratio as all my digital 720p movies) in the following bitrates; 3000k, 2000k, 1500k and 1000k and non have worked (140 says "all skipped, can't play videos"). My test video is only 5 mins.
Basically I'm looking for the highest quality that I can convert my current 720p 3000k mp4's to, that will play the best on the 140.
Currently using a 4gb SD card, reads fine with pics (wallpapers). Going to wait to go bigger till I figure this out.
Thanks in advance for your help.
Christian
Posted May 04, 2012 · 22:36 UTC#2
h264
640x480
Bitrate must be under 1k for the complete stream try - 800k bit rate for video 128k bit rate for audio
file size under 2gb
Posted May 04, 2012 · 23:19 UTC#3
The iPod setting in handbrake works well.
Posted Jun 13, 2012 · 17:52 UTC#4
Im having a similar issue with my z120 video playback through the SD. it says "all skipped, can't play videos". i've tried .AVI, and .MPEG, and i've done so using handbrake with both settings mentioned above and still no playback. what am i doing wrong?
Edited Jun 13, 2012 by XenuStardust
