Hey everyone i have been having a lot of problems with my car and after researching all types of car forums and going to my mechanic and dealerships to try to get this problem fixed, i figured its time to ask around here.
I drive a 2006 trailblazer SS. Came with factory Bose speakers, and amplifier, navigation, onstar. I replaced all speakers and radio. I have the Z130bt, using axxes GMOS-04. I also have 3 kicker amplifiers in my car, 3 subwoofers, 3 sets of alpine speakers, avital remote start.
So everything worked perfect for over a year. The other day i disconnected my battery to take the battery cover off. After hooking the battery back up i notice that the radio is on... no key in the igniton, car is not on but radio it. So i turn my car on and off to get it to shut off, it doesnt. I try everything to get the radio to shut off and it just wont. Unhooked the battery and connect positive and negative terminals to ground out the car, that didnt do it. eventually i pulled the fuse and went to school.n my way to school i went to lower my rear windows and they wouldnt go down... everything else on the door worked except the rear windows. About 8 hours later after class im driving home and now NOTHING on my drivers side door works. cant put down any windows, heated seats, mirrors, nothing works completly dead.
So i do a lot of researcxh and find out that the GMOS-04 module is pretty crappy and has a tendency to blow/die/crap out. I take my car to the audio place i got it installed at. And they reran the power wire to the headunit, so it now works. The radio turns on when i turn the car on, and shuts off as soon as i turn the car off. Previously before this problem it used to not shut off until i opened the drivers side door.
Then i bring my car to chevy for them to try and fix the door problem. They told me the switch in the door is bad and it will cost 433$ plus tax to fix. So i did not have 500$ to drop on it so i took my car back. i did a little experiment and took the "bad switch" and put it into the passenger side door, and tryed to lower the windows.... it worked. Everything worked from the drivers side switch when it is installed in the passenger door. So then i try the passenger switch module in the drivers door. It doesnt work.
So something is wrong with the door. I checked the power wires to the door and they all have power, and all the grounds are properly grounded. I traced all the wires from the door to the harness in the door jam, and then back to the Body control module, theyre all in tact, no breaks or corrosion. But the door still does not work?
i also checked every fuse in the car, in both fuse panels. I have no check engine lights. i disconnected the fuse for the radio and for unstar and tried the windows and they still dont work. I also unhooked the GMOS-04 completly and tryed the windows, still no luck.
So my question is does the Z130 or GMOS-04 somehow hook up to the drivers side door? Could that be whats causing the problem? Do i have to put my stock radio back in, should i just replace the GMOS-04. Anyone have any ideas? I know nothing about how radios are hooked up and know nothing about on star.
any help is greatly appreciated! if anyone can help me fix this problem i would be forever grateful this truck is my baby!!! lol Thanks in advance everyone.
Kevin
