z130 with dashcommand in 2003 Cobra
By Nacman · May 06, 2012in General💬 15 posts👁️ 2,675 views
Posted May 06, 2012 · 23:44 UTC#1
I made this video for the DashCommand forum, but I thought I would post it up here as well.
Nacman
Posted May 07, 2012 · 00:17 UTC#2
This does require a jailbroken iPhone with a tv out extension correct?
Posted May 07, 2012 · 02:00 UTC#3
Since mine is jail broken, before I answered I loaded the dash command app on my wife's which is not jail broken and it worked exactly as you saw in my video. Of course I bought the cable from pioneer that plugs into z130, but that's it.
Nacman
Posted May 07, 2012 · 04:11 UTC#4
Yeah, no jailbreak required. DashCommand is an AppRadio compatible app.
Posted May 09, 2012 · 13:13 UTC#5
I tried downloading dashcommand this morning. I put the radio (Z130) in app mode and all I get is a blank screen (even when not moving with the parking brake on). I assume you need to do the HU mod to get the app to run (especially when the car is moving)?
I'd like to use the app, but $50 is a little pricey if it won't work...
Rick
Posted May 09, 2012 · 16:06 UTC#6
Are you using an authorized cable not purchased from eBay or Amazon?
So am I to assume you are using a pirated version then? Often they tend not to work properly.
Edited May 09, 2012 by VBLUE42
Posted May 09, 2012 · 16:20 UTC#7
Yes - it's version 2.9.1...I guess my point it that I have no problem paying for it (and I will) if it will work in app mode without modifying the head unit. That's all I really wanted to know...
Posted May 09, 2012 · 16:21 UTC#8
And yes - the cable is the pioneer cable purchased directly from pioneer...
Posted May 09, 2012 · 16:23 UTC#9
Your manual should indicate if the P Brake is required to use App Mode.
Posted May 09, 2012 · 16:24 UTC#10
But if the Dash Command app supports App Mode it will work.
Posted May 10, 2012 · 13:31 UTC#11
Update...
Just talked to Pioneer. According to them, app mode on the 130bt DOES NOT support video while driving. While Dash Command DOES support app mode (while in park) - as soon as I put the car in drive, the screen goes blank.
Nacman - is that the case with yours? Or did you do the 130bt mod? Does anyone else have any experience with Dash Command (or similar like Rev, etc.)?
I have all the latest software (including the PAID Dash Command 3.0) and an iphone 4...
Posted May 10, 2012 · 14:54 UTC#12
All video screens are locked out while in motion unless you have the bypass. App Mode uses a video input.
Posted May 11, 2012 · 14:39 UTC#13
I guess I'll be performing the bypass this weekend...
Posted May 11, 2012 · 20:24 UTC#14
Yes, Mine is bypassed. Works fine while driving. The first thing I did before installing the radio was bypass it so I never faced the issue.
Posted Nov 24, 2012 · 00:44 UTC#15
I usually don't bring topics back from the dead, but an update. I just updated the Z130 to using the easy install from here. Now the dashcommand app's soft buttons now work on the display, so I don't have to touch the app on the phone. Big improvement.
Nacman
