Appradio 1.7.0 update. Does it break appradio extensions?
By shaunspad · May 07, 2012in AppRadio, AppRadio 2, AppRadio 3💬 16 posts👁️ 3,847 views
Posted May 07, 2012 · 15:10 UTC#1
I just ran thought the radio update to version 2.5 and all is well with appradio extensions. However because of Mikes's fine work I'm always cautious when updates to firmware or the iPhone app comes out. Has anyone tried the 1.7.0 release to see if anything breaks with appradio extensions?
Posted May 07, 2012 · 15:13 UTC#2
I didn't see any issues.
Posted May 07, 2012 · 15:34 UTC#3
If Mike didn't encounter any issues then that's good enough for me. Much appreciated Mike! Your extensions make this product an amazingly versatile car audio system. let's just hope pioneer keeps improving it.
Thanks for the quick reply.
And for anyone else asking this question. According to mike it's safe to update the iPhone app radio app as it still works with appradio extensions.
Posted May 07, 2012 · 18:19 UTC#4
All app Icons come up with a generic grey icon
Any way to down grade?
Posted May 07, 2012 · 18:21 UTC#5
No, unless you backed up the ipa from iTunes before upgrading. I just tested my version and I didn't see any gray icons. I think they just get cleared from the cache and take a while to load back up.
Edit:
They look fine on the radio's screen but show up gray in the app's setting. Looks like they introduced a new bug.
Edited May 07, 2012 by mikedecaro
Posted May 07, 2012 · 19:28 UTC#6
I have 1.5.0.ipa if anyone needs it
Posted May 07, 2012 · 20:22 UTC#7
Hi all,
I accidently updated my iPhone app to the latest AppRadio. I had 2.22 on my HU. When I tried to use the AppRadio it gave me a black screen for anything other than the home screen. So I went ahead and updated to 2.50. I couldn't use AppExt because I earlier had to updated to iOS 5.1 (phone issue). So I went the tethered route to Jailbreak my phone. So with this said, my brake bypass is broken and will not let me get to apps at all, even if I'm parked and do the process they want you to do. Mike's AppExt doesn't appear to work either or I can't tell because I can't get past the warning screen.
Posted May 10, 2012 · 16:26 UTC#8
Rosno
The ability to use the apps that require the parking break to be set isn't contingent on appradio extensions. Pioneer has changed the way this break thing works at least once now so only an actual switch will continue to work if an when they alter it again. I would suggest a full factory reset on the head unit then make sure you're using a switch to see if you can get your parking break apps to work.
Posted May 14, 2012 · 23:42 UTC#9
Could someone post the 1.5.0 ipa? I wanted to do some testing with it. Thanks!
Posted May 14, 2012 · 23:44 UTC#10
Just a heads up. You can't simply copy the ipa files from one computer to another. They are DRM'ed and only run on devices linked with the same iTunes account.
Edited May 14, 2012 by mikedecaro
Posted May 15, 2012 · 17:36 UTC#11
Yeah -- if you DO do that, you need to use crackulous. Luckily, I still had appradio version 1.5.0 installed on my ipad, and I used crackulous to rip it/transfer it to my iphone.
So -- on AR 1.7.0, I'm finding that the enhanced app mode doesn't work on the old firmware (I'm still on factory firmware). I know I should upgrade, but being a longtime follower of the jailbreak community, in that world we don't upgrade our firmware unless there's a damned good compelling reason to do so.
Dropping down to 1.5.0, I've had no problems with the current firmware. Something has changed, but I'm not quite sure what. Also, for the record, tomtom works beautifully with this hack :) That is probably the SINGLE biggest utility I see in this so far :)
Posted May 15, 2012 · 18:08 UTC#12
MOD EIDT: POST DELETED!!! Post containing references to pirated material are not allowed on this forum.
Edited May 17, 2012 by VBLUE42
Posted May 17, 2012 · 02:59 UTC#13
I just saw on the AppStore that pioneer is calling 1.7.0 "incompatible" with appradio 1. Try are saying not to update if you have AR1 O_o
Posted May 17, 2012 · 03:23 UTC#14
Ridiculous. How can they release an update to an app that people already use and say it's not compatible with their receiver.
"This release is not compatible with SPH-DA01 and can cause malfunctions if used on this product. SPH-DA01 users should not install the Version 1.7.0 update.
SPH-DA01 users who have installed this version 1.7.0 and have experienced malfunctions on their product after the update should do another firmware update. Please refer to the Pioneer Corporation website for more information."
Source: http://itunes.apple....d434811742?mt=8
With that said, I don't have any issues running this version on an AppRadio 1.
Edited May 17, 2012 by mikedecaro
Posted May 17, 2012 · 05:30 UTC#15
That's actually the reason I downgraded. It worked at first, but then the enhanced app mode stopped loading. The screen would just go black. If anyone needs version 1.5.0 because of this issue, I can post a non-drm'ed version I cracked.
Posted May 17, 2012 · 06:39 UTC#16
If you have version 1.5, I'm interested :-P
Edited May 17, 2012 by msieurlolo
