F90Bt Reboots when Selecting Destination Only
By #1 Guru · May 08, 2012in Problems/Troubleshooting💬 2 posts👁️ 887 views
Posted May 08, 2012 · 02:11 UTC#1
I have done every possible thing to the point of restoring this back to factory files. It works great till I select a address then click go once i do it reboots, I can listen to the radio, Watch movies for days and nothing reboots unless I select a place to go. Is there anything I can do. It may be my map files I notice it only does it when I put 2009 or 2010 maps in the unit. Althoug i cloned my Wifes F90BT because hers Don't do this just mine.
Help please
Posted May 08, 2012 · 02:57 UTC#2
Is it a specific location? Are you running mods? Of so which and are they current? Are you running hacked
Maps, by the sound of it you are. Does the unit run done with stock files on there?
