all works except blue tooth. cant load new firmware because its in debug mode. cant get firmware # either. how do i get out of debug mode?
avic f700bt debug mode
what do you mean debug mode? who says its in debug mode?
it says it top left screen when i go to service info. then under that on the screen buttons it says debug mode and i can turn on or off but it never goes off.
anyone?
Never seen this did you buy it this way?
not sure. it shut off while driving. i only had ot a few days so i qas not that familiar
i hit reset several times to no avail. after truck was off for a while it then came back said fatal av error bit it works except no phone stiff.
hold in the restart button on the unit for about 10 seconds, and see what happens. Also if you are mechanically inclined and feel okay with doing it dissconnect your car battery and then re-connect it. This will cut total power to system and make take you out of this mode. If those dont work I would go into testmode and place a fresh copy of someones myflashdisk in there and see if that cures the problem. I have never seen this debug mode on my unit and other then these ideas I am not much more help
If only bluetooth not work, download from pioneer original bluetooth software. Install over edited F700BT and voila it works again !!!!
It sounds like he tried to and it wouldn't allow him.
