Appradio 2 and Android Phones
By uribees · May 11, 2012in AppRadio, AppRadio 2, AppRadio 3💬 21 posts👁️ 7,705 views
Posted May 11, 2012 · 07:22 UTC#1
Hi everybody this is my first post. I recently setup my appradio 2 with the android connection kit sold by pioneer but I am having trouble connecting it to my EVO 3D. The radio will not allow me to use the advanced app mode. I am only able to see a mirror of my phone screen on the appradio 2 screen. What am I doing wrong? I have everything hooked up correctly, the bluetooth is setup, and everything is correct but still no control. Has anyone else had this issue? Does anyone know how to resolve it?
Posted May 11, 2012 · 12:45 UTC#2
Are you getting an error message? If so, what error are you getting? I thought mine wasn't working, but I was confused by the app. Once I had everything connected, and clicked into apps, you have to click in the white bubble that appears and everytime it moves. I was confused on this and just saw a blank background. Everytime I clicked just the blank screen I would get the error message that the connection failed and asked if I wanted to retry. After figuring it out, mines working perfectly.
Posted May 11, 2012 · 15:37 UTC#3
Yeah that part confused me too at first, they do that to calibrate the touch screen, once the calibration was complete everything works very well.
Posted May 12, 2012 · 18:01 UTC#4
Did you also have to connect the parking break wire for this? I'm thinking I need to go with the relay "solution" for this.
Posted May 12, 2012 · 19:59 UTC#5
I didn't do the calibration thing, there was absolutely nothing in the manual about it!!!! I'm gonna try that today, fingers crossed :) As for the parking brake relay thing I was able to bypass that. My friend is a professional installer so he made it so that the radio thinks the parking brake is off when its actually on and vice versa. To make it short he reversed it so I do the steps opposite.
Posted May 13, 2012 · 07:41 UTC#6
Thanks guys that did the trick. That had been bugging me forever!
Posted May 17, 2012 · 16:33 UTC#7
Hello... newbie here on the forum.
I installed my App Radio 2 yesterday and am using it with a Droid Razr. I am having a problem accessing the apps though. When I plug my phone in on the units screen it is a mirror of my phone and goes constantly from landscape to portrait of the installed appradio app on my phone. Can someone please assist?
I have the bypass installed and I dont think that is the issue.
What are people selecting as the view mode when your android device asks you once the HDMI is plugged in?
Thank you for any help!!!
Posted May 17, 2012 · 17:36 UTC#8
If you run the AppRadio app on your phone, connect the HDMI cable and connect via bluetooth, you should see "the bubble" screen - black background with a while bubble. Touch the bubble on the radio, and it'll move around - 5 times for me IIRC - and then the radio should be paired with the phone and the radio screen should start working properly.
Posted May 17, 2012 · 18:45 UTC#9
I reset the device and after it played around for a few seconds of switching between landscape and portrait what your talking about happened. I got it all set up. Thanks for your helP!
Is there anyway to listen to local radio and use Waze or Maps at the same time? If not I sure hope that Tunein becomes app compatible fast! ;o)
Posted May 17, 2012 · 21:49 UTC#10
You can listen to local radio while in "apps" mode by double clicking the "home" button (quickly) and a small menu appears across bottom of the screen, on the far right side it says "mix" if you press it you can mix app audio with either the tuner (radio) or the ipod app if you have one plugged in.
Posted May 18, 2012 · 02:29 UTC#11
OK. Im back again. I think i may have gotten a bad unit. I have not been able to connect since the first time. Now, my phone wont connect to Bluetooth. It connects then disconnects repeatedly. Sometimes it will stay connected but it is not being identified as an android phone. I have a droid razr. Thoughts?
Edited May 18, 2012 by branshaw09
Posted May 18, 2012 · 21:42 UTC#12
Make sure the radio tuner is off, it seems to mess with the bluetooth connection for some reason, once connected it's fine to turn the tuner on.
Posted May 18, 2012 · 22:19 UTC#13
Can you explain a bit more? Thanks
I think i have figured it out. It seems to be a touchy sequence. What i don't understand though is why does it ask me to pair on my phone every time? Its thi normal? All of my past Bluetooth units asked me in the initial set up and the was it.
Edited May 19, 2012 by branshaw09
Posted May 19, 2012 · 01:52 UTC#14
Thank You, after this (which I should have figured out on my own) everything works great! I'm running a custom Ice Cream Sandwich rom to boot.
Posted May 21, 2012 · 19:34 UTC#15
For some reason now for me to configure and do the white dots on the screen it is showing the dots on my phone and not on the AR. In order to see them there I have to enter "mirror" mode on my phone. The more and more things start happening make me think that I got a bad unit.
Posted May 24, 2012 · 15:48 UTC#16
This may seem like a silly and simple question, because I think it is, but when you connect your Moto Android phone do I need to set the HDMI to Mirror for everything to work? I was thinking that once connected the AppRadio app would launch and I'd have function to those apps without selecting anything on the HDMI connection options in the drop down box.
Scenario 1: I didnt select anything and when I dont do that I get the "Warning watching video in a moving car is strictly prohibited" prompt and when I click my bypass I get the Motorola logo screen saver.
Scenario 2: BUT when I select Mirror mode I get the AppRadio App launch and then when I click the bypass I get full access to my phone.
I am thinking that I do have to select an HDMI option, but was expecting that the app would recognize the HDMI and then launch itself. I dont think that's the case now though.
Can someone clarify for me? Thank you VERY much!!! This is a great site and community just like most forums out there.
UPDATE: Ok so now nothing gets me into the appradio app mode. This is getting VERY frustrating. When I plug in the phone and everything is connected, appradio app says to connect to the phone but it doesnt just shows to plug in the hdmi cable, I get NOTHING at all no matter what I chose. It is like the app is not recognizing that the cable is there.
I'm about to take this thing back and find something more reliable. I can't troubleshoot every time I hook it up.
Edited May 24, 2012 by branshaw09
Posted May 25, 2012 · 00:22 UTC#17
I just downloaded the update for the AppRadio app today and about to see what improvements they made. Have you done that already?
Posted May 25, 2012 · 14:20 UTC#18
Yes, it just updated to make the Galaxy Nexus compatible.
I figured out a way to trick my system. If I put the phone in mirror mode and then go into my apps and open up the music player or one of the compatible advanced apps it then asks me to set up the phone and go through the touch screen dot portion. Everything then works fine. Unfortunately it makes me do this step EVERY time. I think this thing has huge potential and hopefully Pioneer is watching these threads and the Play Store comments to see how many problems there are. I got my system from BB and am a silver member so I have 45 days to return I am going to continue to tinker with this thing before I give up. I feel like I'm getting closer to the way I want it daily.
Pandora however... thats another story. When I access pandora from the AR2 I get no audio through the head unit. The visuals are there but the audio is now playing from my phone? Thoughts?
Posted May 27, 2012 · 15:43 UTC#19
Relay doesn't work on appradio 2. Here is a wiring diagram of how to bypass it with a switch (note: each time you flick the switch, it is like you either putting the parking brake up or down).
http://i.imgur.com/fnamG.png
Posted May 27, 2012 · 15:45 UTC#20
Posted Jun 01, 2012 · 21:03 UTC#21
I have a Samsung galaxy s2 and having trouble with appradio 2. The picture keeps on disconnecting. Has anyone else had this problem? It will work for a bit but then sporadically the picture will disconnected and I'll have a black screen. I've checked the hdmi cable and it's connected fine and I'm powering my mhl adapter via the ciggy lighter.
