Problem playing DVDs and pictues on PIONEER headunit
Bypass it, problem solved.
and what about the cameras problem?
the Bypass will work for your dvd issue... did you try switching the ground/battery setting for your camera in the system menu?
tried to do so, but it didnt work at all.
it works only when the ignition is on and engine off.
What camera did you buy? I just installed my camera the other day and it works fine when my car is in reverse.
I just reread your original post. It seems we have similiar issues. Mine works in reverse but if I manual turn the camera on I get a black screen and the caution screen is reversed disclaimer.
any idea about the camera's problem??
any help? -.-
I'm not an expert but I did just install the 8400 with a Koolertron backup camera in a Miata so I'll explain how I did it which worked for me
The instructions for the camera were a little hard to understand, initially it didn't work. What wound up working is this - my video cable had an RCA plug on each end and a red wire. On the camera end I hooked the red wire on the video cable to red and the black wire from the camera was grounded. On the radio end I hooked the red wire to a switched accessory +12 source and plugged in the RCA off course. Then on the radio there is a wire for "reverse sense" which needs to be wired to something that gets +12 when the car is put in reverse, I got that by running a separate lead from the radio to the back of the car and tapping in to the lead for the backup light. Theoretically you should be able to pick this up back in the headunit area from the cars harness but it didn't work on my particular car so I ran the lead.
Your green wire problem is doing what it is supposed to do, it needs a double pulse to close the screen interlock. In other words if you wire it to the parking brake the procedure is to apply / release and apply again to get the picture to show. Micro-bypass sells a $20 bypass that works well, it is the one described as "for AVH-8400", the cheaper $10 one does not work for this unit.
