How to remove dust behind touch panel?
By rgarjr · May 15, 2012in General💬 3 posts👁️ 885 views
Posted May 15, 2012 · 05:25 UTC#1
Pioneer did an absolutely shitty job sealing the display to prevent dust from getting in between the display and touch panel. Anyone found a way to clear it out?
Edited May 15, 2012 by rgarjr
Posted Nov 14, 2012 · 23:36 UTC#2
I have the same problem.. If anyone have a way to clear it out?
Posted Nov 14, 2012 · 23:41 UTC#3
find the service manual (there are links here - also can search elektrotanya.com) on how to remove and disassemble from panel. If you are not comfortable with disassembling electronic components (including ribbon cables, etc, then you might want to take it to a specialist.
You should be able to separate the touch panel overlay from the lcd panel and clean it with a soft clean, lint-free cloth
