Installing CB-IB100 and CD-BTB200
By ttran · May 15, 2012in General💬 8 posts👁️ 2,409 views
Posted May 15, 2012 · 21:51 UTC#1
Can you install the Ipod and Bluetooth Interface Module if there's only one IP-BUS input for the AVIC-Z3?
Posted May 15, 2012 · 22:27 UTC#2
Yes but the BTB200 is not the BT module that should be used with the Z3.
Posted May 16, 2012 · 00:46 UTC#3
Which BT Module should I use? I have an upgraded Z3.
Posted May 16, 2012 · 02:09 UTC#4
ND-BT1.
Posted May 16, 2012 · 04:27 UTC#5
The ND-BT1 seems to be discontinued. Will the BTB200 not work along with CB-IN100?
Posted May 16, 2012 · 07:53 UTC#6
As vblue said, the ND-BT1 is for the Z1-Z3.
Posted May 16, 2012 · 08:00 UTC#7
I believe the BTB-200 will work for BT audio but I don't believe it will work for handsfree. Forum member garrettoomey could probably verify for sure.
