New F40BT (Z140BH) few questions...
By Ibanezwizz · May 16, 2012in General💬 9 posts👁️ 2,287 views
Posted May 16, 2012 · 07:36 UTC#1
I have read the manual - top to bottom - twice!
Some annoying things or am I missing something...
1. Is there a quick sound mute button or a shortcut anywhere?
2. Phone dialler; speed dial for your top ten contacts?
3. Downloaded POI base speed cams. If not navigating (just have nav running without route) no warning on speed cameras is given. It shows other POI's overlaid ok. Is this stupid or what?
4. This will probably have to be a hack mod; is there a way to turn disclaimer off so it doesn’t appear at every start up?
Posted May 16, 2012 · 07:51 UTC#2
1. Not unless you have steering wheel controls.
2. No.
3. Yep.
4. There may be a hack for that. Search over the Z1xx series threads.
Posted May 16, 2012 · 12:14 UTC#3
AFA mute, it isn't exactly instantaneous, but press and hold the Voice button (lower left button) to toggle mute on/off. DOn't need to read the manual twice, just get the PDF file and search for mute.
Posted May 16, 2012 · 12:58 UTC#4
Ha ha ha good one. I meant I read it cos i wanted to understand the whole unit. But you are damn right! Thanks.
Posted May 16, 2012 · 13:10 UTC#5
Also as far as the speed cams (black spots) POI's are concerned, there is a limit on how many the unit will take. Firstly, I've downloaded the whole of Europe speed cams via POI base software which was fine but software wouldn’t copy all EU countries to SD card. I then disabled the limit in POI base software (as per their instructions - saying AVIC imposed this limit but users had success loading all POI’s by disabling the limit). I did this, it then loaded onto SD card ok but AVIC would not import. Once I re-enabled the limit in POI base software AVIC accepted the reduced POI’s but I had to omit 6 countries.
This is stupid! So if I drive from Italy to UK by the time I cut across France I am out of speed cams.
Ideas, workarounds?
Posted May 16, 2012 · 14:46 UTC#6
You are lucky you didn't have one of these units when that limit was set to 300. If I remember correctly it is at 1000 or 3000 now.
Posted May 16, 2012 · 19:49 UTC#7
My god you are kidding me!
I hear you about iPad solution. I thought of this ages ago. I wish iPad would also come in 7 inch version for car use. Problem solved.
Posted May 16, 2012 · 20:44 UTC#8
Rumor has it that is exactly whats coming in about 2-3 months. I will be incorporating it into my brand new Honda CR-Z if that is the case.
