Considering upgrading x920bt to x940bt...
By DeEePiDDy · May 19, 2012in General💬 13 posts👁️ 3,516 views
Posted May 19, 2012 · 02:04 UTC#1
I currenting have the x920bt installed in my car with the video bypass, rear view camera, and ASWC steering wheel control installed.
If I were to upgrade to the x940bt could I just swap out the headunits or would I have to use the new harness adapters, redo the bypass, and reprogram the ASWC? or could I just plug in all the connections from the x920bt and everything will work? I really dont want to have to rip up my dashboard...
Posted May 19, 2012 · 03:03 UTC#2
I'm not an installer so I could be missing something but I would be surprised that you'd have to do anything else besides replacing the head unit. From what I understand, the difference between the x930bt and the x940bt is software and I would expect that would go for the x920bt. The bypass is the same on all X series and ASWC shouldn't change.
Posted May 19, 2012 · 03:42 UTC#3
Direct swap, plug and play.
The bypass is the same on all X series.
Not exactly. There is a difference between 1st and 2nd gen X series.
Edited May 19, 2012 by VBLUE42
Posted May 19, 2012 · 14:49 UTC#4
Thanks for the clarification!
Posted May 21, 2012 · 04:20 UTC#5
What about if I wanted to Upgrade to the Z140BH? Would this also be a direct swap, plug and play?
Posted May 23, 2012 · 18:55 UTC#6
now i can see a reason to upgrade from a X series to a Z series, but why would you want to upgrade from a 920 to a 940?
Posted May 24, 2012 · 17:20 UTC#7
Well will it be plug and play? Or will I need to redo the bypass etc..
Posted Jul 06, 2012 · 13:58 UTC#8
Wanna sell the 920? ;-)
Posted Jul 12, 2012 · 19:00 UTC#9
the biggest reason I am thinking about upgrading my X920BT to the X940BT is the AHA Radio & Pandora support for android...
Posted Jul 18, 2012 · 14:50 UTC#10
That is software and should be available on the X920BT when the X940BT update is released.
Posted Jul 18, 2012 · 20:42 UTC#11
So is the hardware from the x920bt to the x940bt the same?
Posted Jul 23, 2012 · 02:15 UTC#12
I have a 920 so I take it there will be at some point another upgrade like there was when the 930 surfaced? Maps too?
Posted Jul 23, 2012 · 03:37 UTC#13
Yes.
Yes.
