After i did a pioneer official firmware update, it's not working anymore. Can't get into windows Ce.
FW 3
FW 3
Did you make a backup before you started the update ?
i did but not getting into Windows CE anymore
you mean in testmode ?
As far as I understand in these forums (but correct me if I'm wrong) you should always be able to get into testmode if you have a sd-card with the testmode-files on it in the pioneer when its powered on.
When in testmode you can copy back the files you made backing up before you started to upgrade.
Well testmode is working again now
coping some files into the igo map voor data
read about it here it needed data?
Was planning to place teleatlas / tomtom q4 2011 later
but lets see what this brings
Gues i am better in flashing motherboard and videocards ![]()
But as long i can get in to the testmode and windows CE al is fine
maybe start a complete retry from scratch? format the flash drive?
DO NOT FORMAT FLASH DRIVE! Put your origional backup back on. If it was working that way. Leave it as is. If you want to replace maps you need to really understand what you are doing and have all appropriate files otherwise your unit will hang. Make sure you keep your backup copy of MY FLASH DISK in a safe place.
To previous poster no, some times you cant even get into testmode if you mess with things too much.
Crap i did a format and my orginal backup is not working
still hanging on the first screen not the jpeg anymore but that splah screen i gues it's called
when i did the 2009 upgrade, i still have that complete package.
Will attempt to set this one back
