This forum has been great.
Follow-up question after reading this post.
My backup camera (Sony) also has a clamp connector to piggy back onto the reverse lamp lead for 12+. Assumingly to only get power for when the car is in reverse. not constantly.
But.. As Stated above. The HU will allow me to toggle to my reverse camera for forward operation like towing. However if my camera PSU only turns on hooked to reverse lead, then forward operation won't get a signal with no power to camera AV.
I'd like any advice on my options:
1) run the camera to constant 12V (maybe distributed off my lower gauge subwoofer lead?)
- if I kept blowing fuses or the PSU can't handle continued use this might not be a good option to blow a capacitor in there.
2) keep camera on reverse lead (plus connected HU to this lead) and submit to F**ng Sony
Couple other random Questions befor I dart peeling panels off...
I understand you want the fuse to be as close to your power source, but in a camera mount, can't the trailer wiring location/harness be used to get the reverse lamp and/or constant power and other control signals.
The fuse is to protect your accessory, so if it's all in one place from a lead to other accessories factory ready, then is there any loss to hooking into that?
Like for instance to compromise maybe hook the camera PSU power into the taillamp/parking lamp lead on the trailer wiring so I could still power it up by the steering wheel without needing to be in reverse. Sucks at night, the camera will always be on.
Now if we can only record to an SD the camera in case of accident. That'd be a cool option. Mount camera front and back.
Have a great day if you read this post.
Thanks to all who contribute. I've learned a lot in the past week.
