Initial observations about the Pioneer’s flagship F40BT
By Ibanezwizz · May 21, 2012in General💬 5 posts👁️ 1,637 views
Posted May 21, 2012 · 09:16 UTC#1
These are my initial observations about the Pioneer’s flagship F40BT unit (costing about 1,300 Euro) after some extended testing:
Initial install; as you wire the unit (per install manual) when you turn the headlights on unit enters night mode. In most UE countries headlights during the day are mandatory, so unit going to night mode in such manner is thoughtless. Every tinny mobile phone has a light sensor build in nowadays, why doesn’t this unit?
Unit is too bright in night mode, especially on dark roads - no adjustment possible. Map should be much darker grey! It’s fine for well-lit cities but overly bright for rural areas.
No direct speed dialling for 10 or so contacts!
No display (on main navigation screen, although ample space available) - miles/km to destination, just arrival time? Every 70$ Garmin portable navigation has this. It is useful info.
POI’s. As you purchase speed cameras POI’s, you get no warning about speed traps (black spots) if in follow map mode (no route set). So unless you set your route for every trip, every time, you will get no speed camera warnings (this is really annoying and ill thought).
Sometimes I wonder who are the geniuses who sit in the boardrooms at the design stage, advising about the unit? Clearly they never drove a car and have no idea of what are some basic requirements of a good navigation system!
Those things sorted, unit has a great potential.
Posted May 21, 2012 · 22:52 UTC#2
Canadian cars also have day time running lights. If you connect the signal wire to the dash lights instead of the headlight power you'll only have night mode when you have your dash lights on.
Press and hold the mode button to get the picture adjustment screen. Details on pg.157 of the english manual. Keep in mind you adjust for each mode so GPS, sd video, dvd, radio, ipod and night and day for each.
If you touch screen on KM to destination it changes from distance remaining, estimated arrival time and travel time remaining. Yes only 1 at a time but all easily available. Pg 27/28 of the manual.
Posted May 22, 2012 · 06:56 UTC#3
I read the manual twice, must have been dozing off at those pages and picked up on the next page.
Thanks. Much happier now.
My remaining points remain though...
Wiring to dash? My dash comes on when I turn headlights on?
Posted May 23, 2012 · 13:22 UTC#4
Definitley a dry read :?
What kind of car is it installed in?
Posted May 24, 2012 · 15:28 UTC#5
Porsche 911.
