F700BT Memory Issues
By ScottL4619 · May 23, 2012in Problems/Troubleshooting💬 2 posts👁️ 631 views
Posted May 23, 2012 · 00:30 UTC#1
Is there a way to clear the memory (RAM) on these units? When I first loaded the 3.1 update, everything was operating properly. Now, I seem to get the "out of memory" error more and more frequently. I turned off the bluetooth and switched to 2D maps hoping that the unit would use less memory to run this way. It worked for a while, but now, even a route across town will slow everything down so badly that I miss turns because it is catching up. It is almost like I have less and less available RAM as time goes on.
I would even be willing to do a "factory" reset back to the original 3.1 install if that is possible. I have searched this forum and the internet with no real solution.
Any help is greatly appreciated in advance!!
Posted May 23, 2012 · 09:59 UTC#2
I would go in and clear log/save files in test mode and possibly delete maps that you will never use... Ie if on east coast may not need Hawaii Texas Cali ect
