I am getting z1 installed right now and i can not find vss wire for my yukon .. if anyone knows where it is or where i can look on site .. please help
mark
mark
Speed Sense= green/white instrument cluster, pin A4 or PCM
The PCM (Powertrain Control Module) is in the left front of the engine compartment to the left of the fan shroud. The VSS wire is in the green plug, pin 50.
thank you very much you are the man i am in circuit city right now ..
mark
massachusetts
just a question there was a post earlier i have been going nuts looking for it. it was a link to a site that when you put your year make model it gives you the info for the vss wire .. anyone that can help i would appreciate it
thank you in advance
mark
mckzx9
i use directwire. dei's database.
it asks for a password .. there was one i used it just asked year make model and it showed a diagram..
till
i could not found yours
check a post up youll see the pass
You can also get it at the smaller harness behind the radio, the same color. I think my favorite password for directechs has to be f**ckyou. Three guesses as to what the 2 * have to be replaced with.
lol...
i did use password but did not help me . it was a different site .. but i do appreciate the help...
