Hi All,
i come to you to may be find a solution to revive my F900BT..
Yesterday the car battery went dead.. tried 3 times but car stuck dead..so i went to the autorepair an bought a new battery unit. I replace the dead one and when restarting the car i noticed that my F900BT unit did not start.. i took a look at the car system as i know that whith the manufacturer car system you need to activate them.. here nothing like that.. so i came to the abrupt conclusion that my unit was dead also!!! ![]()
now what it does (or not..)...
when starting the car the unit starts also but screen remains black and the MAP and MENU buttons are blue.. few seconds after the blue light ends and the unit is still with a black screen but nothing more.
i tried to use testmode but nothing still the same results.
So i tried to update WINCE using Service mode (i push MENU + MAP + EJECT at the same and reset = i come directly to service mode) Note that service mode can be also accessed only pushing MENU + MAP and reset....
so in servie mode i can browse through the different settings like Upgrade WINCe.. Here i try to upgrade using different BIN images but the only thing the unit does is read the files and display READ PROCESSING 100% and then nothing again..
so i can't upgrade neither...
i'm really desperate to get that unit back to life (my wife want to get her baby back!!
FYI i have another unit F900BT in my second car so i can use it for the backup files as they are with the same modifications.
I'm also downloading TAIL24 huge file to check if his testmode 2.3 can work on my unit as all other have failed..
So if someone have some hints, infos, tips, i would really appreciate.
Cheers from France BTW ![]()
Treker
