Has anyone managed to increase the space on their F90BT?
insert SD card ![]()
but seriously, there is only 2 GB NAND flash onboard. You would need to resolder flash chips... Not worth it on this line...
insert SD card
Is there a way to launch maps from the SD card instead of the main folder?
nav software is igo8, so you can look around on internet about sys.txt how to specify alternate content (map/poi/etc) folder locations
