Really need help with "fatal application error message".
By usafguy69 · May 30, 2012in Problems/Troubleshooting💬 24 posts👁️ 5,014 views
Posted May 30, 2012 · 21:59 UTC#1
Hey Im new to these forums. I recently bought a used avic f700bt and had everything hooked up and working properly in my Toyota celica until I realized I couldn't access the settings so I unhooked everything and found a loose wire (the e-brake wire). I was told to that it needs to be plugged into a red socket so I found an open one next to my e-brake so i did that and everything was working fine. I could access the settings and then I reset the ecu in my car (to disable CEL) and when I turned it back on an error message came up saying "Application ezrider has performed an illegal operation and will be shut down". I tried calling the company and had no luck. I don't have the original CD that came with it either. It seems like a good unit, I just replaced a double din BOSS unit for this one and would hate to see this one go. Please help me.
Posted May 30, 2012 · 23:20 UTC#2
Read in hacks how to do a soft ebrake bypass mod. Or grab someone's mod in hack mods section. Is it only when you are driving this comes up or at start up?
Edited May 30, 2012 by tail24
Posted May 30, 2012 · 23:49 UTC#3
every time on startup even if the cars not running and just the battery is on.
Posted May 31, 2012 · 00:24 UTC#4
Put the wire you moved back in its original spot.
Posted May 31, 2012 · 01:23 UTC#5
I tried that I unhooked it (the e-brake wire) and restarted it and still get the same message every time. I tried holding the reset button for 5 seconds pulled all fuses both for the radio and the one on the radio and nothing has worked.
Posted May 31, 2012 · 01:23 UTC#6
Posted May 31, 2012 · 01:24 UTC#7
sorry for the double post.
Posted May 31, 2012 · 01:42 UTC#8
Idk disconnect battery if you feel comfortable doing so and reconnect. Install problems really aren't my cup of tea... Haven't modded my harness in like 3 years
Posted May 31, 2012 · 01:59 UTC#9
I already tried that :( thats how I reset the ecu. Is there anything software related I can do, or anything else?
Posted May 31, 2012 · 02:07 UTC#10
Can always try to go into testmode. I'd load 3.0 files then grab Daftia's mod and load that over it. It can't hurt.
Posted May 31, 2012 · 02:11 UTC#11
How would I do that? I don't have any experience with the software on these but I do have an sd card which I know I need.
Posted May 31, 2012 · 19:34 UTC#12
Right now both the mute wire and the e brake wire are not connected to anything and I can access the main menu and play cd's for about three minutes until it cycles back into the loop where it restarts
Posted May 31, 2012 · 21:46 UTC#13
Download torrent, get into test mode and upload a fresh backup.
Posted May 31, 2012 · 22:17 UTC#14
Can you please let me know how to do that? And I'm not sure what firmware I have, I can't access my settings. Thanks.
Posted May 31, 2012 · 22:26 UTC#15
I will in a few hours ok
Posted May 31, 2012 · 22:54 UTC#16
okay thanks!
Posted Jun 01, 2012 · 01:22 UTC#17
go to this thread ; http://avic411.com/index.php?/topic/34050-torrent-full-of-avic-f-files/ download the zip with a torrent file with in it. Use a torrent downloader (Azerus Vuze, Utorrent, Bittorrent, ect) to download the larger torrent to your computer (its 8.4 gb and should take much of the rest of the evening to download). Once these files have been downloaded
1. Format an SD card that is at least 2 gb big.
2. Unzip the file you have downloaded
3. Locate the File Testmode V 2.3. Open folder Copy the folder within entitled "testmode"
4. Paste that file into the root level of your SD card
5. Locate folder "My Flashdisk Back up" Open it then Open the folder 2.0 f700 Copy this folder
6. Paste that file/folder into Root level of your SD card along with "test mode"
7. Eject SD card and head to car
8. Put SD card in avic and turn it on
9. wait for avic to load into test mode (likes like windows 95 its called WindowsCE)
10. Click Start > Programs> Windows Explorer
11. Double Click SD card > Double Click f700 up top click edit>select all then Edit>Copy
12. Click Start > Programs > Windows Explorer (again) to open a second finder window
13. Double Click "My Flash Disk" that looks like a grey little icon
14. you will see a bunch of folders and icons it should look similar to when you opened F700 folder from SD card Click uptop Edit Paste
15. If you are given an error message about not enough room ignore or x it out ( i forget the exact step)
16. If asked if you want to replace file, select YES ALL
17. You will see that its gonna take upto 2 hrs but in reality it takes about 15 minutes to replace all files.
18. Once its finished turn off our car
19. eject SD card
20. Turn on Car hopefully at this point it loads perfectly like its a new avic... this may take a few momments and in initial menu it will say please wait system start up in process.
21. If its stuck in loop mode put SD card back in and re enter test mode go back to "My Flash Disk" delete all the files that say "gpspara(number).bin
If this doesnt work you need further help which is doable in most cases but its more indepth. This at least will give you a basic understanding of how to navigate inside WinCe
Posted Jun 01, 2012 · 01:32 UTC#18
thanks so much for the help. Ill give it a try tomorrow and will post the results back here when Im done. thanks again!
Posted Jun 01, 2012 · 01:55 UTC#19
go to this thread ; http://avic411.com/i...f-avic-f-files/ download the zip with a torrent file with in it. Use a torrent downloader (Azerus Vuze, Utorrent, Bittorrent, ect) to download the larger torrent to your computer (its 8.4 gb and should take much of the rest of the evening to download). Once these files have been downloaded
19. eject SD card
& do you think I should do this with the e brake and mute wire un connected?
Posted Jun 01, 2012 · 02:00 UTC#20
i am always a fan of having things connected as the should... or at least grounded properly.
Posted Jun 01, 2012 · 02:24 UTC#21
Okay.. thanks again for the help
Posted Jun 02, 2012 · 13:22 UTC#22
Hey so I did everything and it finally works again! Everything was very simple to do and Im no longer having the message come up. Thanks a lot!
Posted Jun 02, 2012 · 16:35 UTC#23
Great now I'd hey the soft mod on there prOd through applying my 3.0 with daftias backup using directions from above that way don't get error message again
Posted Jun 02, 2012 · 18:28 UTC#24
so I should update to 3.0? Are there any big changes?
