Switch from F90bt to x930bt
By gman86 · Jun 13, 2012in General💬 8 posts👁️ 2,769 views
Posted Jun 13, 2012 · 12:37 UTC#1
I currently have an f90bt. I have had the same problems that has plagued most other f90bt owners. Mostly the screen is not very responsive. I was thinking of getting an x930bt. Are there any major / common problems that i should be aware of? Doing a quick search through the forum it seems to be a solid nav. Any input would be appreciated. Thanks.
Posted Jun 13, 2012 · 17:31 UTC#2
other than a lot of people complain about the nav itself, the system is better than the older units, however before buying a whole new unit, have you tried any custom mods?
Edited Jun 13, 2012 by 1loudls
Posted Jun 13, 2012 · 19:50 UTC#3
I was wondering if the wiring harness and plugs would be the same on the x930 as the F90. Does anyone know because i was thinking about doing the same thing. My unit is toast won't load.
Posted Jun 13, 2012 · 21:55 UTC#4
nope, all harnesses are different
Posted Jun 16, 2012 · 02:16 UTC#5
I just upgraded from the f90bt to the x940bt and though the RCA harness is completely different, you can use the connector from the f90bt with a little effort. It will save a lot of effort from trying to swap them from the minor differences especially of if you soldered and heat shrunk all the speaker wires like i did. So what are the differences:
1) There is only one blue/white wire that will connect to both to the antenna relay AND any remote power switch controllers (like an amp). On the F90 these were separate, one on the RCA connector and the other on the Power so you will lose one. Called pioneer on this and they said to use the one wire and connect it to the antenna and any power switch.
2) The sub RCA connectors are now on the unit vice the RCA connector. So now all that i use on the RCA connector is the rear view camera and the mute wire for the by-pass.
One or two of the names might be different for the wires but they are similar and easy to figure out. I recommend using the F90BT power connector to simplify the swap, honestly. GPS, Mic, SWC, IP-bus, antenna, are all the same.
Thought I'd throw my 2 cents into the ring.
Posted Jun 19, 2012 · 14:38 UTC#6
Thanks for the feed back. I have done a few mods to the f90bt and installed the latest update for the software, but is there a mod/hack that improves screen responsiveness?
I was hoping the wiring harnesses were the same, infact I was so sure they would be I was just going to plug the unit in. I am glad you pointed that out.
Posted Oct 20, 2012 · 12:09 UTC#7
You can delete this post.
Edited Oct 24, 2012 by Labgate
Posted Oct 22, 2012 · 15:32 UTC#8
gman86 for your f90bt, what version are you on?
The latest is 4.001, and it's more responsive than older versions - but x930bt and friends do startup a bit faster and are a bit more responsive (mainly due to being newer hardware models)
