Z140BH Reverse Camera View Not Working
By lorettaboy · Jun 13, 2012in Problems/Troubleshooting💬 6 posts👁️ 2,634 views
Posted Jun 13, 2012 · 16:50 UTC#1
So i just installed my new head unit, upgrading from the Z110BT. Did the bypass, and all seemed to be okay. Problem is, the reverse camera view doesn't work. It goes split screen, but the camera portion is blacked out. The backup camera does work when in reverse.
I noticed last night that the backup camera re-activates once I turn the engine off. Not sure if this helps. Any advice would be appreciated, thanks
Posted Jun 13, 2012 · 19:49 UTC#2
Did you check the polarity setting of the camera under the settings menu? It can be set to battery or ground.
Posted Jun 14, 2012 · 02:52 UTC#3
How did you wire up the camera? Did you use 12V ignition power or did you just use the reverse lamp power? Sure sounds like you used the reverse lamp power which explains you get a black picture when you're not in reverse.
Edited Jun 14, 2012 by rgarjr
Posted Jun 14, 2012 · 12:49 UTC#4
Yes, i have switched it back and forth, but no luck.
Posted Jun 14, 2012 · 12:50 UTC#5
Not sure, i had a professional installer do most of the work. The only thing i did was the bypass. I'll ask him though, thanks for the help!
Posted Jun 18, 2012 · 11:47 UTC#6
Your installer was lazy and used the Reverse lamp voltage for power.
