Anyone know if the WRI-P will work with the 940?
PAC WRI-P and X940BT
A reviewer on Amazon said it worked well on his X930BT so I would assume that it would work on a 940. For $18.35 + shipping, it might be worth the experiment. Let us know how it works if you try it.
I will, if I go with the X, I might just go with the Z series since I like the larger screen. Still debating....
Anything that works for any unit in this series all the way back to 2009 will work.
Just installed the WRI-P on my X940BT - yes it works. Using that flat rectangular remote, not sure what the model number is.
I wish these remotes had a pause button...
Installed the system and the WRI-P and it works, but it also has a bug. I have a GM so I have the retained accessory power circuit (turn key off, but keep doors closed and the accessories remained powered for 10 minutes, believe most vehicles have this today). When I turn off the key and the system goes into the RAP mode, the radio starts scanning stations. This was very consistent. If I unplug the WRI-P from the unit, it no longer scans and just remains at the last station and plays.
I have written PAC to see if they have heard of this problem, and if not, I need to send the unit back for replacement.
