F700BT Won't output to front amp from iPod
By LilDrunkenSmurf · Jun 19, 2012in General💬 2 posts👁️ 923 views
Posted Jun 19, 2012 · 05:48 UTC#1
Hey guys,
I recently picked up an F700BT, and it works great. I ran into the typical "my ipod doesn't have sound issue!" that I resolved by changing the AV1 input. However I have another issue, where when in iPod mode, it won't output to my front speakers, which work fine in FM mode.
My rear speakers are wired directly to the stereo, however my fronts are wired to a 2ch amp, and using the RCA outs on the F700BT, therefore skipping the speaker wires directly from the stereo. My subwoofer also has issues with iPod mode.
Is there an easy setting I'm missing somewhere? All my speakers/sub works fine with AM.
Thanks,
LDS
Posted Jun 19, 2012 · 06:01 UTC#2
I'm an idiot. I found the solution.
Just in case anyone else run's into the same problem: I had my amps hooked up to the power antenna wire as opposed to the remote wire, so I had to go in and change the power antenna from "radio" to "power".
