My truck has the infinity non nav system. I'm installing Avic-x920bt. The wiring is a bit confusing...now mine has the factory amp so from what I read on the PAC c2r chy4 is this correct?
I found this on another post....is this correct? So you take the front outputs from the pioneer deck and wire them to the rear of the PAC harness? So how will the front speakers get sound?
Description for PAC * PAC C2R-CHY4 * AVIC-920BT * Description for AVIC
Battery +12V (2 of these) * Yellow * Yellow * to always on power
Front L- * White/Black * Green/Black * Rear L-
Front L+ * White * Green * Rear L+
Front R- * Grey/Black * Violet/Black * Rear R-
Front R+ * Grey * Violet * Rear R+
Ground (2 of these) * Black * Black * Ground to metal body
Antenna On Input (NU) * Blue * *
Accessory Output * Red * Red * To Electirical terminal controlled by ignition switch
PB Output * Red/white * Light Green * Parking Brake
VSS Output * purple/white * pink * Car Speed Signal Input
Illum Output * Orange/white * Orange/White * to lighting switch terminal
Reverse Output * Green * Violet/White * Reverse Gear Signal Input
SWC Output (on 11 pin) * white/green * *
Amp Turn on Input * Blue / White * Blue/White * Auto Antenna Relay control
Rear L- * Green/Black(NU) * *
Rear L+ * Green (NU) * *
Rear R- * Purple/Black(NU)* *
Rear R+ * Purple (NU) * *
* * White/Black (NU) * Front L-
* * White (NU) * Front L+
* * Grey/Black (NU) * Front R-
* * Grey (NU) * Front R+
Thanks in advance
