I've got a UK F900BT that I'm about to upgrade and am struggling to find out how to backup the existing files! Millions of posts saying that I should but posts saying how are proving elusive.
Can anyone enlighten me?
Sussed it, test mode included in the hybrid 4.001 files gives you a basic windows environment (Win CE) which you can use to copy and paste them onto the SD card.
I to have finally decided to try to update my f900bt so I can use my IOS 5.x device to play video, am looking to back up my current system so I have a fall back. A while ago I saw something pinned. As I have been away from this site for sometime a step by step would be great.
Bearir,
Be warned, an iphone using iOS5.x will not play video if you touch the video button on a F700BT. It crashes the unit and causes it to re-boot. To play video, you change the video 1 input to video and can then play youtube videos, etc. This is an issue with the iOS firmware documented elsewhere.
Did you mean F900BT Doug?
DougG,
tried changing video 1 input to video and F900BT still re-boots
It's an iOS issue... Not much can fix it depending on the app you're attempting to watch video on
