I have tried to make a folder on my usb for music videos and for some reason I do not see the folder nor any of the mp4 videos that I have created. I have tried to use handbrake to change the bitrate because I have seen that some users are unable to play videos because of bitrate and screen resolution. I have done all of this and still cannot find the folder I have created or any of the videos that were put on the usb drive. Any help or thoughts would be greatly appreciated.
Video Files Not Shown From USB
You didn't make a 2nd Partition on your SD card did you?
The units can only read the first partition.
Another option might be that you need to re-scan your SD card on the Head Unit.
My HU has a DB button, that will index and store that catalog onto the SD card in the /data folder.
if you have this folder, then you probably should try to see if you can either:
a ) delete the data folder on your computer so it will rebuild the next time you load the SD in the Head Unit
b ) Try to find the DB update command through the head unit to re-index your SD card, and see if that helps.
Also, I believe only certain file extensions are recognized..
for example a Transfer Stream (.ts) file from a TV Capture won't even show up. but if I rename to .mpeg / .mpg it shows up and plays fine
Hope that helps
