avic d2 subwoofer won't funtion in cd mode
By dlsipe1 · Feb 03, 2007in Problems/Troubleshooting💬 6 posts👁️ 1,327 views
Posted Feb 03, 2007 · 20:08 UTC#1
I need some help. My sub won't function when in cd mode. works fine in fm radio. I even went to the audio menu from cd mode and made sure the settings were on. Any suggestions will be appreicated. :(
Posted Feb 03, 2007 · 20:17 UTC#2
Which blue wire did you use for remote turn-on?
Posted Feb 03, 2007 · 20:34 UTC#3
I used the power antenna. hmm. What other power source should I have used. (or do I change the power antenna settings?)
Posted Feb 03, 2007 · 21:01 UTC#4
You should use the one labeled Remote Turn On
Posted Feb 03, 2007 · 22:27 UTC#5
I have been known to miss the obvious. Thanks!
Posted Feb 04, 2007 · 06:55 UTC#6
Made the change this evening. Worked like a charm.
